  1. Francisco Hernandez
    Francisco Hernandez New Member
    Sep 2, 2015
    Has someone some reference to join the criterion of R&R and FMEA?
    When GRR's result is bigger than 10 %, exists some way of defending this value bearing in mind the result of the RPN?
    A spreadsheet of Excel found in Internet shows that when GRR's value does not overcome a value of 37.8 the system of measurement can be used in a reliable way, nevertheless, I do not find a direct reference to any document of the AIAG, someone can help me?
  2. Atul Khandekar
    Jul 24, 2015
    376
    266
    Pune, India
    Can someone help Francisco with this query ?
    Francisco, can you provide a link to this Excel sheet ?
  3. Ganesh Sundaresan
    66
    36
    In my limited exposure to MSA and fairly higher exposure to FMEA, I haven't come across anything like accepting the Measurement System based on RPN relevant to the characteristics being measured. But can it be taken into account? I think that's little fishy and paradoxical because RPN has a Detection number that assumes acceptable Measurement system, doesn't it.
  4. Dave Mahon
    Dave Mahon Member
    Aug 10, 2015
    There's that fuzzy area between 10 and 30, where the application MAY be acceptable. I would think you could base this acceptance on a low severity rating.
  5. Atul Khandekar
    Jul 24, 2015
    376
    266
    Pune, India
    Well, I found the file. It appears to be a Delphi PPAP file.
    On Sheet 13 it says:
    I am not sure where the 37.8 comes from...or there needs to be an assumption of some 'threshold' RPN value.
    Ganesh Sundaresan likes this.
  6. Bev D
    605
    663
    The MSA should determine the detection rating.
    A few cautions:
    - The AIAG guidelines are not mathematically correct in addition to being very fuzzy.
    - The detection rating is too often opinion and not based on a real R&R study.
    - The RPN value is also mathematically corrupt.
    As Dave mentioned, a low severity will make a low detection ability acceptable. so if you are in the 20% or greater AIAG zone, a low severity failure makes that detection level OK. but if the severity is very high and there is no other mitigation then detection is critically important.
    Occurrence is irrelevant. (occurrence and detection are dependent on each other and occurrence is a variable thing...)
    so the RPN itself is not relevant.
    Severity and actual R&R are relevant.
  7. DavidD
    DavidD Member
    Sep 30, 2015
    24
    I'm always highly skeptical of using the percentage metrics (10% or 30%) for evaluating standard R&R studies as they provide very weak estimates of process capabilities so the percentages are pretty close to useless in practice. Much "better" estimates/understanding of the effect can be gained by using better estimates of the process (long term study data, etc.). I don't have it readily available but the confidence bounds on R&R studies (readilaly available in std sqc books) are huge so it the alpha and beta risks on selecting a bad gage or rejecting a good gage are very significant.
    David
  8. Bev D
    605
    663
    David those are very valid concerns with the traditional (AIAG, 3X3X10) approach. Fortunately those concerns don't come into play if you use the more robust approach (See my MSA resources in the Resources section under the statistical engineering tab) as advocated popularly by Donald Wheeler.
  9. DavidD
    DavidD Member
    Sep 30, 2015
    24
    Bev, All,
    Thanks, I'm working on reading your MSA posting and seeing if I can get ahold of Wheeler's papers.
    Do you have any suggestions on putting together a good exercise to illustrate the differences between the different techniques and demonstrate the advantages over using the AIAG method.
    Does anyone else have particular experience using this method w/ Youden plots? What industries are you using them in?
    Thanks,
    David
