Process capabilities study mechanical properties
Discussion in 'Capability - Process, Machine, Gage …' started by laffranchinis, Jan 7, 2021.
  1. laffranchinis
    laffranchinis Member
    Jan 30, 2020
    Hallo everybody,
    Does it make sense to calculate Cpk on properties like compressive strengths and moduli?
    I mean, the calculation of such indirect properties is based on different single measurements:
    - dimensions (length/ width/ thickness)
    - mechanical tests
    Thanks in advance for your help
    Samuele
    369
    In my opinion, no. First, there are a lot of arguments against the use of Cpk on anything. Second, Cpk is a calculation based on the mean, standard deviation and specifications. The first two of these (mean and standard deviation) have an associated uncertainty about their values (i.e., confidence intervals). Combining two uncertainties into one equation increases your uncertainty in the result. Now, take modulus with four variables, each of which has two uncertain parameters. You now have eight uncertain values. The confidence limits around the resulting Cpk would be very wide. I recommend trying a Monte Carlo simulation to demonstrate that this is true.
  3. Bev D
    518
    564
    To what end? What do you think it will tell you?
  4. laffranchinis
    Jan 30, 2020
    Hi Miner,
    Thanks for the explanation.
    @ Bev: from time to time our wind customers want that we calculate Cpk based on mech. properties. I already tried to explain them that it make no sense. BTW Miners explanation seems to be more professional, so next time I will try to explain all the story with confidence intervals.
    Stay healthy
    Samuele
  5. Miner
    369
    If you can provide the equation, means and variances, I can run a Monte Carlo simulation to show the resulting confidence intervals.
