  1. leomac83
    leomac83 Member
    Aug 22, 2019
    I've a question: Is it correct when I say that during an OQ protocol must be tested all the CPPs and their ranges?
    Thanks.
    Pharma GMP Annex 15:
    Critical process parameter (CPP): A process parameter whose variability has an impact on a critical quality attribute and therefore should be monitored or controlled to ensure the process produces the desired quality.
    Operational Qualification (OQ): The documented verification that the facilities, systems and equipment, as installed or modified, perform as intended throughout the anticipated operating ranges.
  2. leomac83
    leomac83 Member
    Aug 22, 2019
    Are there opinions? Anyone?
