Level 1 policies - risks and opportunities
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by Christian Ullrich, Jul 24, 2017.
  1. Christian Ullrich
    Christian Ullrich New Member
    Jul 24, 2017
    Do level 1 policies need risk and opportunity verbage in the document? We currently have risk based thinking represented in our level 2 processes but not the level 1 policies.
    5,086
    2,553
    Christian, what are "level 1 policies"?
  3. Christian Ullrich
    Jul 24, 2017
    The Level 1 policy is a corporate global policy statement for different operations like Product and Process development, Production operations policies. Our level 2 documents are processes, level 3's are work instructions and level 4's are forms. We have added risk and opportunities to our level 2 processes.
    5,086
    2,553
    When you say "do level 1 policies need risk and opportunity verbiage" are you asking if there's a requirement someplace? If so, the answer is not in ISO 9001. In fact, you decide what and how you are going to address risk and opportunity and if/how it needs documenting.
  5. David Bradley
    David Bradley Active Member
    Aug 2, 2015
    57
    55
    Michigan
    Back in the early days of ISO 9001/QS 9000, each of the 20 elements typically had a policy (level 1 document), followed by a procedure (level 2 document). After ISO 9001:2000 came out, a lot of folks quit using the individual policies for each section of the standard. I see very few companies that still use separate level 1 documents for each clause or section. I expect to see even less with ISO 9001:2015. As far as the OP's question, if you feel a need to have risks and opportunities outlined in any documentation it would be up to you. As Andy stated above, ISO 9001 does not require or mandate any particular verbiage.
  6. johnnymo77
    johnnymo77 Active Member
    Sep 1, 2015
    51
    Niles Michigan
    This is how we have been doing it.
  7. RoxaneB
    Somewhat off topic, but...I remember the whole level 1, level 2, etc. era and I never quite understood it. For example, a level 2 procedure...well, is there a level 3 procedure or a level 1 procedure. By Johnnymo77's definition, no, there isn't. So, why not just call a procedure a procedure and call a work instruction a work instruction? Why clutter the management system with extra verbiage?
    5,086
    2,553
    It was a corruption of the original ISO 9001 requirements, RB. ISO 9001 specified in clause 4.9 that process control could be achieved through the use of "documented work instructions, where the absence of such would adversely affect quality"
  9. RoxaneB
    The need for the documentation, I understood. It was the need to say "Level 2 work instruction" instead of simply calling it a "work instruction" - the numbered levels never added value, in my opinion.
    5,086
    2,553
    Right, it came from the hierarchy created - at least implied - from the way ISO 9001 (1987, 1994) was worded.
