How to meet requirement of work environment/environment operation as per ISO9001 2015 standard
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Rajan Gupta, Jul 6, 2018.
  1. Rajan Gupta
    Rajan Gupta Member
    May 30, 2016
    44
    What all activities could be to be performed inorder to meet the enivorment for operation of work in a manufacturing company.
  2. Qualmx
    You have to take into account the next:
    - Temperature in places where people work
    - Adequate light, lamps
    - Noise, allowable according to the environment
    - Ergonomy
    - others
    in People
    - Stress
    - bullying
    - People relationship
    Take a look to clause in ISO 9001 2015
    Hope this helps
  3. Lafir Ali Rinos
    Lafir Ali Rinos Member
    Jul 1, 2018
    Dubai, United Arab Emirates
    Shall we consider either it may or may not affect product conformity,
    if so shall we raise NC if not conforms to the requirement but conforms to the product
  4. Qualmx
    Dont understand what you mean..
    The standard is clear
    The organization shall determine, provide and maintain the environment necessary for the operation
    of its processes and to achieve conformity of products and services.
  5. Rajan Gupta
    Rajan Gupta Member
    May 30, 2016
    44
    To that case if we dont have temperature any measure to control the temperature than what should we do
    can you better explain the parameter you have define how to define in control plan and is it necessary to define the limits to for this activities
  6. John C. Abnet
    636
    449
    Does your process REQUIRE temperature control? Remember that the standard simply states ...
    "The organization shall determine..." "...for the operation of its processes and to achieve conformity of products and services."
    As you can see @Rajan Gupta , the standard does not specify exactly what shall be done. Your organization must determine how to take care of your people and processes to ensure the
    "conformity of products and services" ".
  7. hogheavenfarm
    This clause is one of the reasons we have moved away from ISO9001. I agree that conditions conducive to quality of the product should be monitored, however the latter part of this clause gets off base. How to monitor a stress free work environment and social interaction for what purpose? This affects product quality? I can see possibly in some cases, but most places I have worked are all stressful environments, product quality notwithstanding. Ergonomics and noise are covered separately under OSHA and the EHS program, usually run by HR. All this used to be under "Resources provided by management" in the old edition. I see too much "mission creep" in this latest edition.
  8. Qualmx
    aS
    As hogheavenfarm said
    It depends of your business, e.g.
    If you produce foods, you need to have a strong control over the temperature, maybe 9001 is not enough, you could have to jump
    to other food standards , (FSSC 22000 maybe), the point is, is very important to control the temperature in your environment and this aspect will be fully auditable.
    But , if your business is an Engineering company, well normally offices have air conditioners, but you dont need to have a strong control over them.
    In this cases, auditors normally dont take care on that.
    hope this helps
