GRR for destructive test-Crimped terminal pull-out force
Discussion in 'Gage R&R and MSA - Measurement Systems Analysis' started by Plague Doctor, Jan 22, 2016.
  1. Plague Doctor
    Plague Doctor Member
    Jan 19, 2016
    Ukraine
    According to customer's requirement we need to perform GRR for conductor pull-out force (wire is being pulled out of crimped terminal using the force gage).
    it is a destructive test: no chance to use the same sample for second time / split the sample and so on, in other words we can do only 1 test for each sample.
    What can we use here? Nested GRR? If yes, is there a different calculation from crossed GRR? I have only standard AIAG form for crossed GRR. Could please someone share the form for nested GRR with me?
    Or maybe we should apply another MSA study? What can you suggest?
    Thank you.
  2. ncwalker
    168
  3. Plague Doctor
    Jan 19, 2016
    Ukraine
    Thanks, but I read this article just before posting here:) I don't have Minitab so I wonder if there is any difference between calculation formulas of crossed and nested GRR or it is just difference in obtaining samples method.
    In other words can I use the same spreadsheet as for crossed GRR or do I need a new one special for nested GRR? And if I need new spreadsheet for nested GRR it would be very nice if someone send me an template:)
  4. Miner
    494
    400
    First, read my blog on non-replicable R&R studies.
    The only option that you have is to use consecutive samples for your study. You might take 9 consecutive samples from 10 different setups/days/shifts. The 10 setups/days/shifts would reflect the parts in the R&R study while the 9 consecutive samples would reflect the 3 repeats across 3 operators. And, nested is the correct analysis.
  5. ncwalker
    168
    The concept is the same - you are checking variances between part/between operator/between trial and coming up with the conglomerate numbers. But the steps are different. Meaning, if you were to put results in Minitab, you'd get different answers running a crossed and a nested study on the SAME inputs. And I believe the nested numbers would be more conservative. I don't have ready access to it. You'd have to search around for the steps on Google.
