Gage Calibrations
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by JohnS, Sep 27, 2017.
  1. JohnS
    JohnS New Member
    Jul 25, 2017
    I am looking into the best way to make sure our pitch mic standards are certified without having to have them redone every year. This system was in place before I took this job and there aren't previous certifications for the standards here. I know I will need to get them certified, but after that, can I just put them into our gage system and make the length of certification good for the life of the standard?
    5,101
    2,557
    I'm not sure what you mean when you say there's no previous certifications, but here's what I suggest: Get your mics calibrated by an accredited lab to "baseline" them. Then set up your recall based on use, not time-based which is always the (ineffective) default. If you are using thread mics frequently on the shop floor, then they may well wear far faster than in a year. I've had screw plug gauges gauging stainless steel wear in weeks...
    The PPAP Assassin likes this.
    The problem is, when you need to get them certified, you may need to get certification from accredited laboratories. These laboratories, usually, set the next due date after they have done the calibration of your standards. If you are the one who will set the length of certification/calibration, you have to demonstrate your organization's capability to perform calibration.
    5,101
    2,557
    Actually, Tony, ISO/IEC 17025 prohibits them from doing this, since they have no idea of useage...
  5. The PPAP Assassin
    Mar 20, 2017
    67
    29
    Kent, OH
    You should order a set of "master" thread gauges to use only for calibrating, maybe just 2-3 standard sizes (Make sure they come with certs). Those "master" gauges would need to be sent to an accredited lab on a 2-3 year basis (or sooner based on usage frequency) to maintain calibration. Make sure the certs they provide are NIST traceable. I used to work for a fastener company and we did this all the time. Think of it as using gauge blocks to calibrate standard mics and calipers. Hope this helps.
    Nice to know Andy. I hope you won't mind if you can post the exact statement and clause in ISO/IEC 17025. I will need to use this as reference. Thanks.
  7. BradM
    BradM Moderator Staff Member
    397
    316
    Arlington, TX
    Here you go (from 2005 version):
    "5.10.4.4 A calibration certificate (or calibration label) shall not contain any recommendation on the calibration interval except where this has been agreed with the customer. This requirement may be
    superseded by legal regulations."
    Intervals need to be risk/usage-based, and there is no way the mfg. knows all the variables. It creates issues (auditors get all nervous) when there is a due date on a certificate and an alternative recall date is used.
    5,101
    2,557
    Thanks, Texas dude!:D
    BradM likes this.
  9. tony s
    Many thanks BradM.:)
    BradM likes this.
