Error caused to produce bad product, once in 5 years, Root cause?
Discussion in 'ISO 9001:2015 - Quality Management Systems' started by Qualmx, Feb 20, 2021.
  1. Qualmx
    443
    58
    Hello everybody
    Recently one of our employees made a mistake and resulted in defective product, this product arrived
    at customer.
    Customer is asking us to do a CA.
    In the analysis, resulted that he had a bad night, was somewhat
    distracted, this employee never makes mistakes, he is a very responsible worker.
    It happened once in the last 5 years.
    At developing the root cause:
    Bad product-> employee distraction-->had a bad night--> noise around house->party of neighbors->>>>
    I think this 5W, stops in had a bad night.
    In this case if you are agree, root cause is had a bad night, if my assumption is fine...
    Questions:
    1-In order to eliminate the root cause, What Can I do?
    2-What action plans can I implement?
    3-Would this root cause will be sufficient to my customer, or will expect something better?
    a deep analysis, other data?
    Or if this was an common error any employee can cause everywhere, any time, could I just
    turn the page and go on?
    And how to close out his CA?
    Please help
    3,937
    1,980
    This is not root cause.
  3. Qualmx
    443
    58
    I don´t have too much practice on this, I got only a little training on Root cause analysis, however, I don´t detect something different.
    I could address it in other way...
    Bad product-> employee distraction-->he didn´t stop the motor at the right time-->because it was sleepy--->had a bad night, didn´t sleep well--> noise around house->party of neighbors->>>
    again, had a bad night, It can´t go beyond that.
    I´m lost
    Your thoughts?
  4. Eric Twiname
    315
    218
    May I suggest that the root cause is the ability of your company to ship a bad part?
    Bad product-> employee didn´t stop the motor at the right time--> no safety interlock to stop the motor at the right time and insufficient QA to catch defective product before it went out the door--> ineffective test and quarantine protocol for out of spec parts---> insufficient QA/QC review of outgoing product.
    No one outside your company cares why it happened...your customer cares why you shipped it and made it their problem. 5-Why around that.
    The problem isn't that a bad part was made...the problem is that a bad part was SHIPPED.
    HTH
    3,937
    1,980
    Once again, why is it "I am doing this"? Didn't your training tell you to put a team together?
    If stopping the machine is Critical to Quality and you have put it on being "awake", then the root cause isn't the operator, it's whomever designed the process and the controls for the process! This operator control should be error proofed. Expecting a process control to be like this, dependent on operators attention, is crazy.
  6. Qualmx
    443
    58
    In my specific case, this was the only time it happened in several years.
    Always have trusted in the operator ability, and the process was designed like that and had been ok, and didn´t detect
    the needed to automating it.
    Now I see I have to implement a control on the motor.
    On the other hand, the operator error, what is a common practice to address this issue?
    Just occasional distraction and do nothing for this case?
  7. Jennifer Kirley
    889
    629
    Qualmx,
    Andy and Eric are describing the need to design the process in a way that does not require the operator to pass a restful night in order to produce good product.
    You did not describe the nature of the defect. Was it about holes being drilled in the wrong end of a part? If so, a fixture might be constructed that allows the piece to fit in the machine only one way. This is just an example. To understand what to do, I suggest reviewing the operations with the operator and identify a way that would make success no longer dependent on perfect attentiveness or peace of mind. After all, eventually it would be a different operator with possibly lesser skills. The process should be able to succeed regardless.
    tony s and Qualmx like this.
    3,937
    1,980
    And you may indeed have been teetering on the edge during that whole period. If you trusted just one individual all the time, you got lucky they weren't sick, took vacation, or similar. Another person wouldn't have been so lucky. Plus you put the whole organization at risk and, furthermore, went against the principles of the QMS. I wonder what kind of mental state the person was in too, having such pressure put on them for so long...
    tony s, Qualmx and Jennifer Kirley like this.
  9. LiviuSt
    LiviuSt New Member
    Sep 27, 2016
    Hello all,
    I have been following this forum for some time and I have discovered quite a few interesting topics. I probably don't have the experience of many here, but now I feel the need to comment a little. I would see this as a good way to improve the process. We can apply 5 Why in several directions:
    1. Why did it happen (occurrence)? In this case, was the operator aware that he was tired? Could he notify the supervisor to be replaced? If the root cause is operator fatigue, isn't process automation justified?
    2. Why was the error not detected (detection)? Is the process controlled enough?
    3. Why was the error not prevented by designing the process (prevention)? Why was no control operation provided in the process? Do the costs due to this event justify or not the redesign of the process?
    Of course, some of these questions were answered in the comments above, but I wanted to exemplify how I would respond to a possible complaint like this. I have noticed that the answer to a complaint is never simple and involves several root causes (in occurrence, detection, prevention) and the most difficult to identify are the corrective actions that must deal with human actions.
    Qualmx likes this.
    3,937
    1,980
    Welcome LiviuSt.
    How about:
    Why did the part get made wrong? Because the process isn't in robust and control and relies only on Operators to "catch" bad outputs
    Why isn't the process in control? Answer...
  11. LiviuSt
    LiviuSt New Member
    Sep 27, 2016
    Quick answer - poor process design. If develop there can be a lot of potential causes, which can be eliminated by analyzing this case.
    Were the outputs of process correctly defined? Are these outputs controlled? I think..."employee didn´t stop the motor at the right time" isn't enough to define the control.
    And we can continue with the method and/or resources and/or the staff involved (training, motivation, awareness, back-up).
    Of course, the correct answer can only be given by the team involved in the analysis of the complaint.
  12. Eric Twiname
    315
    218
    Andy is giving good advice about the process.
    I would add (it's sorta in Andy's too) an after process catch for bad parts (in addition to your in-process ones).
    Bad parts get made...we do our best to limit how often, but we never get 100% yield.
    What is in place to identify the bad part(s) before they go out the door?
    Most places use a second pair of eyes/tests on critical features rather than just the operator who made the part...
    It is in your company's best interest to control the process to avoid avoidable errors...it is demanded by your customer that your errors (however few) don't show up at their site.
    Similar, but different, needs. HTH
    Qualmx likes this.
  13. Scott@jmnspecialties
    Scott@jmnspecialties New Member
    Jun 1, 2020
    I would think that the "had a bad night" is not the issue, or an acceptable root cause. I say that, if there is not, there should be another QC before shipping out the finished product. The person making the product should not be the final QC. Production employees "NEVER" produce a defective product.
