AS9100 7.1.5.2 Measurement Tracability
Discussion in 'AS 91XX - Aerospace Quality Standards' started by Laura N., Feb 28, 2020.
  1. Laura N.
    Laura N. Member
    Sep 23, 2019
    Northern California
    Question regarding calibration - this is kind of a long lead in, thank you for reading until the end. o_O
    We are a small machine shop currently working towards our AS9100 certification. We are 10-12 employees, we have a consultant who is assisting, I was hired to help with this my experience is with ISO 9001 and I was asked to basically be the interpreter, to help the company understand while keeping our certification as simple as possible. The goal is to be able to provide services to new company's, some of which could include aerospace.
    The company has always been meticulous with tracking of material, processes, inspection and all of there processes so my job has been pretty basic to document what they do. Every part is released, every job has first article inspection that is documented, when job is complete every part is inspected through our inspection department, that inspection is documented with material certs and outside process certs, all this is documented and sent with each part.
    We have had our standards sent out and outside calibrated now we need to calibrate our inspection tools. My question is if we are calibrating all of our inspection tools, even our 2 CMM's are outside calibrated do we need to track/calibrate each individual operators tools? Can we mark them as reference since nothing leaves the company without going through our inspection department?
    Thank you in advance! :D
    5,107
    Welcome Laura:
    Firstly, NEVER, EVER mark an item of equipment "for reference only". It's a trap! It's either, "Not Controlled", or "Calibrated", "Calibrate Before Use" or "Verify Before Use" etc. Here's why:
    Operators constantly "reference" (read) their measuring devices. To use the warning "For Reference Only" is a non sequitur. Of course, in using the equipment, the question then becomes, "do you need to trust the reading?"
    Your answer is going to be "Of course" - or the operator risks having their parts rejected by QC (or worse, the customer), therefore some form of verification is going to be required - calibration is simply a "super" verification, after all.
    Put in a program of verification before use and have your operators record that, then have the master gauges they used to verify their equipment calibrated by a trusted lab.
    Laura N. likes this.
  3. Laura N.
    Laura N. Member
    Sep 23, 2019
    Northern California
    Thank you for correcting my terminology, I am showing my ISO age I think.
    Could you please expand on what you said here? Would First Article inspection be verification?
    5,107
    Nah! Many places do similar things...
    Happy to help. I encounter this situation regularly. The FAIR is the results (data) from inspections of the part(s). You generate this report, want to use equipment which is either calibrated - or verified - with traceability to a standard, to avoid a rejection from a customer. If both parties use equipment which is calibrated/verified to standards traceable to NIST/UKAS etc, then - within the limits of uncertainty, the measurement results should give almost identical results, right?
    Now, if your machinists/operators have a selection of equipment to use (their own, your organization's or a mix) to make measurements, then how will you know - in the event of a customer rejection - which specific equipment was used on a feature? I encourage clients to have their OPs records the results of their verifications on the Shop Order/Traveler/Job ticket which accompanies the parts. They know who was assigned to the job, but need a record of which equipment was used and the data from the measuring equipment which was also used.
  5. Ali.M
    Ali.M Member
    Aug 29, 2018
    18
    Manchester, United Kingdom
    Hi Andy, is FAIR a requirement in AS9100 Rev. D. I've scoured the standard and I can't see reference to FAI. I might be going blind or I'm too tired :S
    The reason I ask is, the company I work for is hoping to begin production of 'on-board products' for a major British airline manufacturer. The problem is we have bottle necks in production and the only way to get around it, is to use two different machines that do the same task (to relive the bottle necks). Using the two different machines may have a visual impact on the product but no impact to the customer requirements on the product itself.
    I'm guessing two FAIRs would need to be generate. Is that right?
    5,107
  7. Md. Hasan Ibrahim
    Md. Hasan Ibrahim New Member
    Aug 21, 2023
    Bangladesh
    Certainly, Laura! While your company's meticulous inspection process is commendable, individual operator tool calibration adds an extra layer of precision. It ensures consistent, reliable measurements and aligns with industry best practices. Consider discussing this with the AS9100 consultant for specific requirements. Tracking each tool individually can be a proactive step in maintaining the high standards your company is known for, especially when dealing with aerospace clients. It's like an insurance policy for impeccable quality!
