ANVISA (RDC 36/2015)
Discussion in 'Other Medical Device Regulations World-Wide' started by QAengineer13, Sep 22, 2015.
  1. QAengineer13
    QAengineer13 Member
    47
    ANVISA published today, 27 August 2015, the DRC 36/2015 resolution repealing the RDC 206/06 and RDC 61/11 resolutions, establishing in this way, new rules for Risk Rating, Registration, Registration, Labelling and Instructions for Use Products for In Vitro Diagnostic (IVD).
    The RDC 36/2015 implements several new features, such as the examples below, but you need a detailed reading on the resolution to identify all changes.
    Here are some of the new requirements:
    • Instruments for use in in vitro diagnostics become registered or registered by GEVIT;
    • Products for in vitro diagnostic risk class II shall be subject to Registry (formerly the IVD product risk class II were subject to registration);
    • All products, regardless of risk category should have a Technical Dossier, however, the dossiers IVD Products risk class I should not be sent to ANVISA and shall be filed in the company for disease control purposes;
    • The Technical Dossier has several items / documents, including risk management and usability;
    • Models labeling and use instructions should be referred for evaluation of ANVISA, regardless of the product category of risk;
    • Products subject to Register (Hazard Classes I and II) need not be revalidated.
    Resolution RDC 36, 2015 shall enter into force on 26 October 2015 (60 days after publication).
    Jim Hagenbaugh likes this.
  2. QAengineer13
    QAengineer13 Member
    47
    Recently, ANVISA published the Normative Instruction n°4/2015 regarding INMETRO certification which replaces the Normative Instruction n°11/2014, and the standard IEC61010-2-101:2002 has been removed from the certification scope. It means that INMETRO certification will not be a mandatory item for ANVISA registration requests.
