5.1.1.3 and 5.3 Organizational Roles and Responsibilities and Process Owners
Discussion in 'IATF 16949:2016 - Automotive Quality Systems' started by MCW8888, Feb 17, 2017.
  1. MCW8888
    I am doing an IATF 16949 gap analysis using the AIAG tool and the Quality Manual and also the standards. In the manual the process owners are defined in the roles and responsibilities. Will I have a problem during an external audit if there is no separate paragraph to describe process owners? Thanks.
    4,713
    2,353
    Good question! What were you thinking would be in the "separate paragraph"?
  3. MCW8888
    Do I have to have a section titled Process Owners. I did not changed this section of the manual. But the standard had a separate requirement for process owners. Our SOP's also describe roles and responsibilities. Thanks.
    4,713
    2,353
    Sounds like a matrix added to the manual which relates the specific clause, to where else you covered process ownership would be fine...
    MCW8888 likes this.
  5. MCW8888
    I just did a RACI matrix.
  6. rajesh
    rajesh New Member
    Nov 14, 2016
    what is RACI matrix. please share it
  7. MCW8888
    The RACI Matrix is a powerful tool to assist in the identification of roles and assigning of cross-functional responsibilities to a project deliverable or activity
    RACI represents: R - Responsible, A - Accountable, C - Consulted, and I - Informed
    RACI Definitions:
    Responsible
    = The person who executes the work and makes sure the task objective is achieved. There is only one person assigned as the Responsible role, although others can be delegated to assist.
    Accountable = The person who is answerable for the correct and thorough completion of the deliverable or task, oversees and approves the Responsible tasks and deliverables. There must be only one Accountable party specified for each task or deliverable
    Consulted = The person(s) whose opinions are sought, typically subject matter experts; and with whom there is two-way communication
    Informed = Those who are kept up-to-date on progress, often only on completion of the task or deliverable; and with whom there is just one-way communication
    I might have seen a simple matrix in this forum. We have a complex one for the R&D division, It's a confidential document with names written on it. Hope this helps a bit.
  8. charanjit singh
    charanjit singh Member
    Jan 21, 2016
    32
    For a number of years, I have used Matrix of Responsibility for various processes, using the following abbreviations:
    P = Primary Responsibility of...
    S = Secondary Responsibility or Support to be provided by...
    I = Information to be given to...
    C = Coordination by (this was rarely used)
    No CB auditor ever commented on this.
  9. johnnymo77
    johnnymo77 Active Member
    Sep 1, 2015
    51
    Niles Michigan
    Here's our APQP RASIC as an example.
    MCW8888 likes this.
